- Joined
- Jul 28, 2024
- Messages
- 2,116
Vehicle is a Nissan Rogue after a drive long or short as long as coolant is up to temp when I turn the vehicle off I smell antifreeze. Maybe I’m noticing this more with cooler weather and spending more time in the garage. No visible leaks I’m going to investigate further see if I’m losing any coolant by placing a witness mark on the expansion tank. Last oil change I was looking around under the hood for visible signs “I thought the expansion tank was sort of on the low side for an up to temp engine”
Where to start?
Check radiator cap and replace if necessary replace expansion tank cap?
Thanks all
Where to start?
Thanks all
