I'm going to install a receiver hitch on my 2010 Vibe, so I can use a bike rack.
If I use anti-sieze on the bolts, should the torque be reduced and by what percent?
The torque spec is 86 ft. lb. There are 4 bolts that screw into nuts factory-welded into the frame.
When I was building an engine years ago, someone from a fastener company (ARP) gave reduced torque figures for anti-sieze vs. oil. I wasn't sure if overtorquing would be as critical here as on rod and main bolts.
Thanks All.
Thanks All.
