A ARB1977 Joined Jun 12, 2005 Messages 6,783 Location North Texas May 9, 2014 #1 When doing drum brakes how many of you do this to prevent sqweaks? On my tacoma when I release the brake I get a sqweak that's annoying.
C charbaby Joined May 25, 2005 Messages 16,752 Location ROCHESTER, NY May 9, 2014 #2 Yes, I always use some form of lube(usually brake lube) on the backing plate "tabs" where the shoes meet the backing plate. Use the lube of your choice
M Merkava_4 Joined Jan 30, 2007 Messages 17,501 Location Clovis, CA May 9, 2014 #3 It's been awhile working on drum brakes but as I remember, the shiny spots on the backing plate is where you apply the grease.
E exranger06 Joined Jan 25, 2008 Messages 4,464 Location Guilford, CT May 9, 2014 #4 I use Syl-Glide for that.
C ChiTDI Joined Dec 19, 2003 Messages 2,382 Location Chicago IL May 9, 2014 #5 Bendix Brake Lube works great for that, too. Comes in a large, wide tin that you can scoop with fingers or a paste brush.
C Chris142 Joined Jun 5, 2003 Messages 32,013 Location Apple Valley, California May 9, 2014 #6 antisieze gets hard.use grease
K Kestas Staff member Joined Jun 4, 2002 Messages 14,717 Location The Motor City May 9, 2014 #7 I think antiseize is excellent for this high wash application.
Donald Joined Mar 21, 2004 Messages 33,539 Location Near the beach in Delaware May 9, 2014 #8 I would use a brake lube. Anti-seize may tend to run if the area gets hot.
A ARB1977 Thread starter Joined Jun 12, 2005 Messages 6,783 Location North Texas May 9, 2014 #9 Thanks guys. Can I apply the grease without removing the shoes?
The_Jeff Joined Jun 15, 2003 Messages 43,734 Location ME May 9, 2014 #10 Yeah the shoes are spring loaded in every dimension so you can pry them apart from wherever the grease is needed.
A ARB1977 Thread starter Joined Jun 12, 2005 Messages 6,783 Location North Texas May 9, 2014 #11 Thank you.
K Kruse Joined Oct 5, 2005 Messages 5,657 Location Kansas May 9, 2014 #12 I use a high-temp grease on the backing plate. But use it SPARINGLY. Grease should never touch the friction material.
A ARB1977 Thread starter Joined Jun 12, 2005 Messages 6,783 Location North Texas May 11, 2014 #13 Worked like a charm.
