Anti-Oxidants
MolaKule
Staff member
Iowegia - USA
By now we know that the ZDDP ester has been one of the best anti-oxidant and anti-wear compounds ever developed, which makes it a multi-functional additive component.
But anti-oxidants with zero or very low levels of heavy metal content are more desireable in certain driveline lubricants.
Mercaptobenzthiazoles and beta-thiodialkanols are derived from heterocyclic sulfur- and oxygen-containing compositions.
These anti-oxidants are especially suited what driveline fluid?
Guidelines for the Question of the Day:
1. No Piston Cup Lapel Pin will be awarded to the same person within 14 days of a previous award.
2. Please respond with a complete sentence.
3. Please do not post links. If a question arises as to the need for clarification, then sources and links may be requested.
4. Please, no off topic posts.
Originally Posted By: OneEyeJack
Is the beta-thiodialkanol you reference a monosulfide?
The beta-thiodialkanol referenced contains both a monosulfide and a disulfide, with a majority monosulfide content.
These anti-oxidants were developed specifically for ATF fluids.
When the newer, longer life ATFs were being speced on paper, it was apparent that an improved anti-oxidant was needed in order to remain stable for the so-called "lifetime" fills.
So BITOG member 29662 shall be awarded the extinguished Piston Cup Lapel Pin.
Are these compounds obtained through a mixture of an aromatic amine such as an alkylated diphenylamine and the resulting product of a monohydric alcohol combined with a beta-thiodialkanol (spelling???). In other words is this stuff good for seals and gaskets?
