Guys...had HVAC guys replace vent pipes and the smell I was getting before has gone away.....
Now I've noticed something that maybe has happened all the time but maybe just seeing it now. When the water heater is firing the cold water line gets warm...and warms up decently..is this normal? My thought was that I am getting radiant heat from the flue and this is not a good thing....after everything cools down it seems to still stay warm right at the connection into the water heater...
But then I started to think (which is scary)that perhaps the pipe is heating up because I am heating the water in the tank and that pipe has to go through that 130 degree water so maybe that is where the heat is coming from? It seems to make sorta sense because when I was doing some tests and had WH up to 160 degrees that pipe got REAL warm....at about 130 it still gets warm but not like it did before
Anyone got some tidbits of wisdom? I just don't know if heating up and then cooling off with cold water going through it is such a good thing......will the copper pipe eventually let go if I let it keep cycling like this?
Thanks so much..you guys have been great
Goose
Goose
