- Joined
- Aug 14, 2020
- Messages
- 816
Over the past months, I was impressed by several posts (here and here) concerning a possible fix for oil burning issues in some Toyota engines.
I own a 2010 Toyota Highlander with the 1AR-FE 2.7 inline-4 with 350,000 miles. I have always changed the oil at 5,000 miles with mainly whatever was posted on clearance here at BITOG. Over the past 150,000 miles or so, oil consumption has increased from 0.5 up to 3.5 quarts for the 5,000-mile interval. Gas mileage had also decreased from a range of roughly 22-24 mpg to 20-22 mpg (mainly highway use).
At the last oil change, I tried the Berryman B-12 piston soak by pouring 2-3 ounces in each cylinder and letting it sit overnight. In the morning, cylinders 1, 2, and 4 had barely lost any fluid, while cylinder 3 was nearly dry. I rotated the engine a bit and let it sit for another eight hours or so. Once again, 1, 2, and 4 still had quite a bit of fluid left in them. I used a long blow-gun attachment and some shop towels to remove the leftover fluid.
I refilled the crankcase with Rotella Gas Truck 5W-20 and crossed my fingers. One of the first tanks of gas I ran through posted a tick over 24 mpg - something I hadn't seen in a long time. Gas mileage overall has come back up at least one mpg which is nice.
As for the oil consumption, over the 5,123-mile run the little 4-cyl lost only 0.75 quarts. Not too shabby. I refilled with Mobil EP 0W-20 and will keep an eye on things. Overall, a huge success!
