I got this off of a oil cooler manufacturer's FAQ's section and was wondering if this were true. I am more concerned with the first sentence rather than the rest of the answer because here in TX we hardly ever see sub-zero temps. I thought there was an optimum temperature range for the trans fluid?
Q. Can you over cool the transmission fluid?
A. Transmissions are not highly sensitive to cool operating temperatures. However, in sub-zero (20-30° F) weather conditions transmission fluid can actually gel up in an external cooler and cease to flow, causing damage. Use of the radiator cooler actually helps warm the fluid under these conditions. It is critical in extreme cold conditions to use the original equipment cooler in series with the auxiliary cooler and allow the vehicle to warm up before driving.
