quote:
Originally posted by MolaKule:
Please analyze and critique these claims from a racing oil brochure (emphasis mine) with respect to the tribology and chemistry you have learned here on BITOG:
quote:
Racing Oil
The products are formulated with world-renowned "Bright Stock", which imparts a natural affinity to cling-on to exposed metal surfaces. Additionally, this unique component provides the ultimate in lubrication technology by creating an unprecedented hydrodynamic barrier, which provides critical full-fil strength protection and enhanced shock load capability to protect highly stressed engines. Our "exotic" racing oils provide:
Excellent oxidation and shear stability characteristics.
Outstanding anti-foam system.
ZDDP additive for strong anti-wear protection.
Exceptional high temperature protection from thermal breakdown.
Exceeds the performance requirements of API Service SJ.
Here's my critique... some of them are guesses, but I'll guess anyway!
Bright Stock is world-renowned by who? Bright Stock is just Group I refined petroleum oil. If so, it won't have the polar-affinity for metal that ester-based oils do. (and PAOs? I'm not sure about PAOs)
BTW, wouldn't additives plate-up bare metal surfaces? Unless your molecules are attracted to additive-plated-metal, isn't it a moot point? (and wouldn't the same be true of any oil? That's a noggin scratcher... MolaKule, can you comment on that one?)
By definition, shock loads squeeze out the hydrodynamic oil wedge, and force you into the barrier lube regime, where your plated additives protect from metal-on-metal contact. Your base oil isn't going to help you with shock loading, unless it's high viscosity... and no more than any other base oil of the same viscosity. Plus, isn't shock loading more of a problem for transmissions (gear teeth?) rather than engines?
Exceptional oxidation and shear stability? Perhaps the same as other Group I base oils, but nothing compared to Group II, III, III+, IV or V base oils.
Outstanding antifoam -> maybe, can't tell, they may indeed have an outstanding antifoam additive package.
ZDDP antiwear claim... yes, ZDDP is an antiwear additive... but more additive does not necessarily mean better protection. Additive balance is key (also, slight antioxidant effect of ZDDP)
High temp protection from thermal breakdown? See bright stock = Group I base oil argument. Sure, it'll have protection, but the base oil is among the least able to protect against this.
Exceeds API SJ? That's no claim to fame... we're now at API SM PCMOs. What, did they find some barrels of oil lying around, buy it cheap, type up some advertising dreck, and try to sell this stuff for a premium?
Professor Molakule, can I leave early for my next class? Thanks
[ May 19, 2005, 01:47 PM: Message edited by: bigpaulo ]
