Not if you want fast charging.I don't get it? What electrical panel upgrades do you need? Don't you just plug it in to a household outlet?
Every house built in the last 50 years or more has 220V service. Any electrician can run a line to an outside wall and add a 220V outlet for charging for a coupe hundred dollars.Not if you want fast charging.
Charing an EV on 120vac takes forever. This device attaches to the box that currently holds the meter. It's providing 220vac without having to run a new line or install a new panel. The company is Connectder and is located in Philly.I don't get it? What electrical panel upgrades do you need? Don't you just plug it in to a household outlet? When I had a Leaf I just had an extension cord from the outlet on the front porch to the car.
No, it takes twice as long. Overnight is quite reasonable to be able to use an existing outlet. And how often is the meter anywhere near where the car is parked?Charing an EV on 120vac takes forever.
Not here. 200a didn't start showing up till the 90's. When we redid our house a few years ago we replaced the 40a box with a 200 though.Every house built in the last 50 years or more has 220V service. Any electrician can run a line to an outside wall and add a 220V outlet for charging for a coupe hundred dollars.
It's not 2x. It's closer to 4x to 8x.No, it takes twice as long. Overnight is quite reasonable to be able to use an existing outlet. And how often is the meter anywhere near where the car is parked?
My understanding is that if you have two columns in your breaker panel, then you have 220 capability.Noy here. 200a didn't start showing up till the 90's. When we redid our house a few years ago we replaced the 40a box with a 200 though.
Why? 110 is half of 220 so all things being equal, shouldn't it take just twice as long?It's not 2x. It's closer to 4x to 8x.
Don't you live in one of the hottest places in CA? And your 90's house didn't come with central air?Not here. 200a didn't start showing up till the 90's. When we redid our house a few years ago we replaced the 40a box with a 200 though.
A couple hundred dollars labor excluding materials if a you have an empty two slots in your breaker panel that also is big amperage wise enough to supply a 30-50AMP circuit AND the run is dead simple.Every house built in the last 50 years or more has 220V service. Any electrician can run a line to an outside wall and add a 220V outlet for charging for a coupe hundred dollars.
Well, when I installed my air compressor in the basement, I just taped into my central A/C unit for 220V, ran a line 20' along the ceiling and put an outlet on a ceiling joist near the compressor. $30 in parts. While that might not work for EV charging in the summer unless you shut off the A/C while charging, it might be a possibility.A couple hundred dollars labor excluding materials if a you have an empty two slots in your breaker panel that also is big amperage wise enough to supply a 30-50AMP circuit AND the run is dead simple.
120v at 12 amps is about the max. 1400 watts, approxWhy? 110 is half of 220 so all things being equal, shouldn't it take just twice as long?
Typical 120V outlet is 10A. A pretty simple Watts Law calculation says this circuit can deliver 1200 watts.Why? 110 is half of 220 so all things being equal, shouldn't it take just twice as long?
