Amsoil zero turn lube
MS
Is the Amsoil Zero Turn Hydrostatic Transmission Fluid actually better than the manufacturer recommended 20W-50 motor oil or is it just re-labeled Amsoil synthetic 20W-50 motor oil?
I think about 25 years ago they recommended Mobil 1 15w50 but then changed that recommendation to their own labeled hydro fluid. If I remember correctly the formulation changed with the Mobil 1 and Exmark wasn't comfortable with the new stuff. I've used the Amsoil fluid before and couldn't tell you the difference or notice the difference between any of the hydro fluids.
I am using the Amsoil tractor Hydraulic fluid in my Tuff Tork K66. It is not motor oil. It works good in my Husqavarna. I'm sure it is not motor oil.
20W-50 Synthetic Hydrostatic Transmission FluidHigh-zinc formulation fights wear and helps preserve mower speed and responsiveness.AMSOIL 20W-50 Synthetic Hydrostatic Transmission Fluid is specifically formulated to deliver smooth, responsive operation in zero-turn mowers, stand-on mowers and other equipment professionals rely on to make a living. It fights wear and viscosity loss during continuous, severe-service operation, maximizing mower speed and operability. Unlike motor oils, AMSOIL Synthetic Hydrostatic Transmission Fluid is purpose-built to withstand the unique demands of hydrostatic transmissions. It lasts up to 2X original equipment manufacturer (OEM) recommendations, helping professionals save money and reduce downtime.
