Amsoil zero turn lube
MS
Is the Amsoil Zero Turn Hydrostatic Transmission Fluid actually better than the manufacturer recommended 20W-50 motor oil or is it just re-labeled Amsoil synthetic 20W-50 motor oil?
I think about 25 years ago they recommended Mobil 1 15w50 but then changed that recommendation to their own labeled hydro fluid. If I remember correctly the formulation changed with the Mobil 1 and Exmark wasn't comfortable with the new stuff. I've used the Amsoil fluid before and couldn't tell you the difference or notice the difference between any of the hydro fluids.
I am using the Amsoil tractor Hydraulic fluid in my Tuff Tork K66. It is not motor oil. It works good in my Husqavarna. I'm sure it is not motor oil.
20W-50 Synthetic Hydrostatic Transmission FluidHigh-zinc formulation fights wear and helps preserve mower speed and responsiveness.AMSOIL 20W-50 Synthetic Hydrostatic Transmission Fluid is specifically formulated to deliver smooth, responsive operation in zero-turn mowers, stand-on mowers and other equipment professionals rely on to make a living. It fights wear and viscosity loss during continuous, severe-service operation, maximizing mower speed and operability. Unlike motor oils, AMSOIL Synthetic Hydrostatic Transmission Fluid is purpose-built to withstand the unique demands of hydrostatic transmissions. It lasts up to 2X original equipment manufacturer (OEM) recommendations, helping professionals save money and reduce downtime.
No not relabeled motor oil.
It is better, lasts longer and shouldn't shear as much so better protection for longer, plus plenty of antioxidants that aren't in engine oils. I've had the same fill in my abused Gravely ZT for 4 years now.
https://www.amsoil.com/c/hydrostatic-transmission-fluid/24/?zo=515729
You really should not use engine oil in a hydraulic / hydrostatic system. You want a fluid that is optimized for the application (which does not include combustion) like John Deere's HyGard (J20C, 10w30) or HyGard LV (J20D, 5w20).
https://shop.deere.com/us/search?text=hygard&productType=all
https://jdparts.deere.com/partsmkt/unsecured/document/english/featbene/hygardsalesbrochure.pdf
Amsoil has the following:
ATH - Synthetic Tractor Hydraulic/Transmission Oil
5w30, J20C/D
https://www.amsoil.com/p/amsoil-5w-30-100-synthetic-tractor-hydraulic-transmission-oil-ath/
https://amsoilcontent.com/ams/lit/databulletins/g28.pdf
TCGSB, synth-blend Universal Tractor Transmission Oil (UTTO)
10w30, J20C
https://www.amsoil.ca/p/amsoil-commercial-grade-tractor-hydraulic-transmission-oil-tcgsb/
https://amsoilcontent.com/ams/lit/g3832.pdf
AHF - Synthetic Hydrostatic Transmission Fluid
20w50
https://www.amsoil.com/p/amsoil-20w-50-100-synthetic-hydrostatic-transmission-fluid-ahf/
https://amsoilcontent.com/ams/lit/databulletins/g3471.pdf
Any of these would be excellent in a hydrostatic. The viscosity you require will depend on your ambient & operating temperatures.
I changed the factory Tuff Torq fluid at 50 hours per break in. Then to the Amsoil ATH at 90 hrs, because I had to pull the unit out. This was to beef up the front, and transmissionmission mounting ears. Long story........ I used Amsoil ATH Tractor hydraulic/transmission fluid. It feels a little better than the Tuff Torq fluid. Could be placebo....... Tuff Torq says you can use an engine oil. But conveniently says they want you to use the Tuff Torq fluid.
I feel warmer and fuzzier knowing I have very high quality fluid in the drivetrain. I just have to decide henceforth how long to run the normal intervals. The K66 has an internal filter. So that will need to be replaced at a future interval......... a long while...... ;)
You're confusing me. This is from the manual for my Hydro Gear ZT-2800s
an engine oil with a minimum rating of 9.0cSt (55 SUS) at 230° F (110° C) and an API classification of SL is recommended. A 20W50 engine oil has been selected for use by the factory and is recommended for normal operating procedures.
Most all engine oils will not meet a GL4 level of gear protection which is one reason why Deere uses and recommends HyGard not engine oil.
A hydrostatic transaxle is not a gasoline engine, use what you think is best.
