Amsoil Testing ?
Ndx
IL
Exxon:
The 4-ball wear test is a test designed to evaluate the performance of a gear oil. The 4-ball wear test is not included as a part of any industry-wide recognized engine oil specifications (e.g. ILSAC GF-4, API SM, or ACEA specifications). ExxonMobil does not regard this test as a useful indicator of engine oil performance.
I wonder :) If amsoil spents as much money as exxon on testing .. ?:)
OH NO!
Originally Posted By: buster
http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Amsoil_Wear_Scar_Testing.aspx
the question posted was about Amsoil 4 ball test but the answer was all Purple? FUNNY!
Quote:
Ask Mobil Ask Mobil
Oil Film Strength of Mobil 1 Compared with Royal Purple
Ask Your Stickiest Question. . . Or ask us something you’ve always wanted to know about using our products. We’ll sort through all the submissions and present the best questions to our automotive experts. The questions, and their answers, will post right here on the site.
Question:
Does Mobil 1 have less oil film strength than Royal Purple? I have seen many times the friction test of oils using the machine that test the oil film, test result shows that Royal Purple has more friction protection that Mobil 1 does, seeing these results makes me think that Mobil 1 is lacking some benefits, therefore Royal Purple has the better protection of all.
-- Guillermo Tristani, Miami, OR
Answer:
There are certain oils in the market today that use EP (extreme pressure) additives in their engine oil that are really designed for gear oils and not engine oils. Extreme pressure additives are typically not used in engine oils for a number of reasons but the most important is because they can cause engine corrosion over time. The rigs being used in these demonstrations are primarily designed for industrial applications like gear oils where extreme pressure is an important performance feature you need. These demonstration rigs have very little to do with modern engines and that is the reason that market leading oils in the industry perform poorly in these tests.
Quote:
Ask Mobil Ask Mobil
Question:
Answer:
No........
Somebody had asked a VERY similar question about Royal Purple, and instead of answering the question AGAIN about Amsoil, they link you to the answer to the Royal Purple question:
Quote:
Answer:
Please note that the ANSWER does not single out any particular brand, simply a testing methodology.
Of course Amsoil doesn't spend as much money as all of Exxon-Mobil. But Amsoil is a tiny company compared to EM. That doesn't automatically make EM lubricants better. Now as a percentage of revenue or sales, I have no idea.
The 4-ball test is just an extra test. One of many tests. Indeed it is used for a variety of lubricating fluids, and frankly the topic has been beat to death here.
http://www.astm.org/Standards/D4172.htm
Indeed it has Pablo. A quick search shows that.
"FOUR BALL WEAR TEST (ASTM D-4172B)
Although this test does not simulate any bearing geometry internal to an engine, it is extremely useful in comparing the wear protection properties of various lubricants. Since
the only variable in the test is the particular brand of oil, it provides and accurate comparison as to how well a lubricant will prevent wear inside an engine when compared to another competitive brand of oil of the same viscosity. In other words, it is an “apples to apples” test comparison. The smaller the wear scar the better the protection." Dave Mann
Yeah I think I agree completely with that statement.
Because an engine has more than plain bearings in it. Many have chains, gears, cams and ball and sockets. All sorts of stuff that need oil other than a plain bearing.
From Amsoil
Quote:
The 4-ball test is not a test used to qualify lubricants for engines.
It is an anti-wear test that gives an indication of an oil's ability to
reduce and control wear when two metal surfaces come in contact with
each other. The 4-ball test is an ASTM test and does, in fact, have
good repeatability, more so than many anti-wear tests. The 4-ball has
value for racing applications, as those engines are under stress and
have a high likelihood of metal-to-metal contact. Reducing wear under
those conditions is favorable. The reason we use the test is to
demonstrate our anti-wear technology.
From Jim Fitch
Quote:
Engine Oil Performance Testing
"I have seen a number of lubricant manufacturers refer to the 4-ball wear scar test as an indicator of how well the oil will protect an engine. Other larger companies tend to brush off the results of this test indicating that it isn't representative of actual engine conditions adding that because it is cheap to run, the results aren't worth much. What are your thoughts on this?"
The 4-ball test (ASTM D4172) is often used as a screening test for many different lubricant types that contain antiwear additives or similar base oil properties. Other tribo-mechanical bench tests are often used as well, including the Timken Test (ASTM D2782) and the Pin and V-Block (ASTM D2670). Because engines have different contact geometry, loads, metallurgy and speeds, numerous bench tests and test protocols are needed. It is not uncommon for several oils to be tested using two such methods and to find that the performance rankings between the oils to reverse (no correlation). This is why, among other reasons, Passenger Car Motor Oils and Heavy Duty Oils (diesel crankcase) are tested in actual engines using controlled methods such as ASTM D5533 Sequence IIIE and D5302 Sequence VE.
Jim Fitch, Noria Corporation
XOM claims extreme pressure additives in engine oil can cause corrosion over time. Does anyone know anything about this? See there most resent Q/A on there web site regarding this.
In my opinion, run Amsoil Oil like the other oils and You may find that Amsoil may be like all of the other oils...no special equipment installation, just run Amsoil Oil like you would any other oil through the filter of your choice then run the tests like UOA or whatever.....Amsoil may work as well as any other oil.......In my opinion...
