Amsoil SVG 75-90 or 75-110
I`m using Amsoil 80W90(which is what my car specs via factory fsm). I wonder if 75W110 would be better,or if I should just stick with the oem spec of 80W90?
comparing the old and new viscosity charts
isn't 75W-110 closer to the 212*F viscosity of 80W-90?
and 75W-90 is a touch thinner than 80W-90?
Yes. That's my point.
Just recapping...
If going with 110 SVG over OEM spec of 90 vs OEM fluid - Castrol SAF-XO, with the higher viscos. differential fluid, how much ~hotter~ will the diffy run . Non LSD fluid
You'd have to put a temp gauge on it and find out yourself. There is no answer. Could even run cooler. Depends on diff.
