Amsoil Standalone for Diesels Promoted At Last!
Idaho
Looks like Amsoil is listening and maybe data is flowing in that the standalone bypass is the best way to go.
Amsoil is now offering adapters to run a standalone bypass on the Big 3 Diesels......Bravo
I agree, It seems that filter technology is trending up as far as Full Flow Filters, and I really don't think the Dual System is on part with the "size" of the EAO26 compared to the size of 2 of the 3 big diesels. The Ford PSD and Cummins have very large FF filters. So the best of both worlds would be to run the Stock FF and add on a BMK11 with the largest by pass that will fit.
Too bad there are no standalone 'kits' for the overlooked CRD Jeep diesel. The stock FL400s sized filter is a joke considering the 12.5k recommended OCI.
Does the amsoil kit offer a built in restrictor to keep from starving the engine of oil?
Or do you have to build that into the system?
Put a BP-80-A filter head mounted somewhere, tap into an oil source and return back to a valve cover, oil pan, etc.
EaO BP 90, 100 , 110 are huge bypass filters and keep your fullflow 52 where it is.
LCM, I should have mentioned I have a BMK-17 Dual Remote now. SO I am running the EaO26 and the EaBP-100. I was hoping if I did put the adapter plate on to run the BMK-11, that I could put the EaO26 on instead of the Eao52. I am very familiar of the size of the ByPass filters.
Ok, that makes more since. Any problems/issues with the dual remote? or do you just want to go back to the stock fullflow and the standalone bypass?
No problems at all. I am at 39,000 miles without drain plug removed. I use Series 3000 5w30 in my Duramax and my Jetta TDI.
I really like that cool blue billet oil fil cap.
