AMSOIL Signature Series color change
Missouri
As the title states I have questions if anyone has ever noticed 10w30 SS changing to a deep red, almost like ATF. I know color doesn't mean much but I was just curious if there's a reason why? The wife's 2017 escape is still an amber color but the mothers 2008 grand caravan looks like older ATF.
How many miles? I've read on a different forum that people noticed it turning red whenever oil dies and TAN significantly higher TBN (pretty much oil is dead at that time)
Amsoil dying early?
Get ready!
I have not noticed a change to red color in my applications in my sig. However my mileage is relatively low on my changes, but time is long. I have noticed it becoming slightly cloudy after 2 years in the drain pan during a change. I am guessing the cloudiness is due to moisture accumulation.
Mine turned RED too, I had zero lead on an used oil analysis of Mobil 1 extended on a new car. Then ran AMSOIL Signature Series and did a used oil analysis with 2,000 and had 70 lead, 25 of copper ( they ran the test twice) dumped it and Polaris wanted me to run another exact run to 2,000 but my new fill of AMSOIL Signature Series turned red so I dumped it at 600 miles because I did not want to risk it when I was at 0 lead before using Amsoil. Note: I ran Amsoil many times in other cars, so I am Pro Amsoil, less now though. I went with Mobil 1 ESP and at 1,000 mile used oil analysis I pulled a 4 ppm lead. It must not be related but I just wanted it out and back to Mobil 1 that had a 0 lead the test before ( ran twice also) and low copper and aluminum ppm then the Amsoil. Just a fluke , but with a new car I am couldn't risk it.
Curious why does the color changes to red? Is there a specific chemical (different than other oils) which causes that?
I have seen this multiple times as well -- the oil either turns red or a very dark brown. Not sure why...
Has anyone contacted Amsoil about this? Perhaps send them pics and the UOA (?)
I never saw weird color changes when I ran Amsoil a few years ago, so I cannot attest to any problems with it.
I haven't done a used oil analysis because I'm not concerned so much about performance, actually the oil has gotten rid of a cold start metallic sound, I was just more curious what reaction caused the deep, dark red coloring
Yes, I noticed AMSOIL Signature Series turning dark quickly as well, in my Ford Ranger. I made a thread about it, maybe around a year ago.
I was using Mobil 1 Extended Performance 0w20 prior to AMSOIL Signature Series. That Mobil 1 in my engine darkened very little compared to AMSOIL Signature Series. Amsoil did this in just a couple thousand miles. Others' results may vary. In my high temperature testing of both oils, AMSOIL Signature Series did darken a little more than Mobil 1 Extended Performance 0w20 but not nearly as dramatically as occurred in my engine. From this thread, it does sound like there is a tendency for AMSOIL Signature Series to darken more quickly than many other oils. I suspect it is not cause for concern.
I'm not concerned just more intrigued as to why it turned into such a deep red color, I've never had an oil turn such a dark red color
Sounds like Esters reacting with Pb? Scavenging? Maybe a small formula change. But, I'm speculating.
I've drained mine at various intervals and it always has a red tinge to it coming out of the oil pan but it's never deep red on the disptick or in the container I drain it into.
