The Kinematic Viscosity of the Amsoil HDD 5w30 @ 100C is 11.5, which is the upper end of SAE Grade 30 (9.30-12.49), which is close enough to the lower end of SAE 40 (12.50-16.29) for your winter use there.
Okay, if your using the 5w30, I would use it year round.quote:
Originally posted by coyotekid:
Gene K,
mssparks,
Would you recommend switching to grades in the summer or just use 5-30 year round? Although I have faith in Amsoil, totally disregarding the owner's manual unnerves me a little. If I ever do have warranty issues, using a 5-30 might be a problem. I guess I can always drain it and put "the right" oil in!
Also, why is the HDD 5-30 better than the 5-40 European? I'm considering just using the 5-40 year round. I'm considering this because I can get some pretty wild temp swings. For example, last June I went from driving in 70 degree weather one day to starting my truck at about 20 degrees the next morning at my job which is at 7000+ feet elevation.
