Amsoil EaO Filter users?
CA
Anyone using the Amsoil EaO filter?
What part # are you using?
What vehicle are you using it in?
What oil are you using?
How long do you plan to run the filter?
EAO-34
Audi TT turbo(1.8L)
Amsoil 0w-30
10,000 miles/1 yr
EAO-20 (oversized substitution for EAO-12)
Subaru
Amsoil 10w-30, Four Stroke Marine
15,000 miles/1 year
Note:
If used with petroleum lubes that generate a higher solids level from high temp oxidation/nitration, I'd suggest a max life of 12k-15k/1 year on this oil filter to avoid clogging....
EaO13-just installed
Honda Odyssey 3.5L iVTEC V6(4305mi)
Honda Genuine 5W-20
10-12,000 miles
Happy New Year
Just started using the EaO-20 filters.
Used in both my Honda CRX and my wife's Honda Civic. Since both of those cars had a bypass system installed before the EaO filters came on the market, the EaO filters are just one more thing to keep the oil extra clean (vs doing all the work by themselves).
Currently using M1. However, I'm thinking of switching over to Amsoil due to M1 forumla changes (once I use up my current stash of M1).
I'll probably change the EaO filter when I change the oil. However, between the bypass, the EaO full flow, and good synthetic oil, this will probably be at least a 10K OCI, and possibly noticably longer (especially after switching away from M1, to the Amsoil noted for long OCIs)...
57
Don't know yet-probably the minivan
probably 0w-10 (cooled)
As long as possible w/UOA support
Vehicle - 2004 GMC E. SLT Cab Z71
Oil - 0W-30 Series 2000
Oil filter - EaO64
Length of use - 1 yr/15,000 miles* oil & filter (change every Nov)
Air Filter - EaA123
Vehicle - 1992 Chevy 4x4 PU
Oil Filter - EaO23
Length of use - 1 yr/5,000 miles* oil & filter (change every Nov)
Air Filter - EaA31
* - Inconsistent miles of use
Vehicle - 2002 Chevy Silverado Z71 5.3 V8
Oil - AMSOIL TSO 0W-30 Series 2000
Oil filter - EaO64
Length of use - 1 yr (oil changed every spring)
Air Filter - EaA123
Vehicle - 2005 Saab 92x Aero 2.0 Turbo
Oil Filter - EaO13 (Oversized version of EaO12)
Air Filter - EaA74
Vehicle - 2003 Harley-Davidson V-Rod
Oil - AMSOIL 20w-50 MCV Motorcycle Oil
Oil Filter - EaOM136C
Length of use - 1 yr (oil changed every fall)
Air Filter - EaAA43701
Vehicle - 2000ish Craftsman LTX1000 w/ 21.5 hp V-Twin Briggs
Oil - AMSOIL ASE 30/10w-30
Oil Filter - EaO57
Air Filter - Briggs
Vehicle - 00 B3000 Mazda
oil - Amsoil Series 2000 0W30
Filter - EaO 034
Annual change
Vehicle - 94 Saurn SL1
Oil - Penz Plat 5W30
Filter - EaO 034
Use - Annual
EaO11
2001 Ford Taurus 3.0L DOHC
Last OCI of Mobil 1 5W-20 was 6.5K (Feb - Dec 2006). I expect similar timeframe of current 5K OCI.
Car - 2005 Nissan Murano
Filter - EAo 12
Oil - ASL 5W-30
Length - 1 year or oil change (6-6500 miles)
Car - 2005 Chevy Corvette
Filter - EA0 - 32
Oil - GC then ASL 5w-30
Length - 1 year or oil change (7000 miles)
EAO57
05 Toyota Tacoma v6
Amsoil (ASL) 5w-30
1k-5k mi/6 mos til warranty expires then 10k+ mi
EAO20
92 Honda Civic
Castrol GTX 5w-30 with Auto-RX clean/rinse phases then Amsoil 5w-30
1,500-2000 miles with Castrol GTX/Auto-RX then 10k+ mi
planned:
EAO20
92 Honda Accord
Amsoil 5w-30
10k+ miles
Has anyone ever, without running a cleaning agent like RX in the oil, had a filter actually go into bypass because it was so full of dirt/contaminants? I doubt it will ever happen in a well maintained vehicle. You are buying into the marketing of the filter companies! I gave up on Amsoil filters when they went to Donaldson, too expensive and K&N, napa all go the one year 10-15000 miles for me without any issues. You know my opinion, oil filters are way overated in doing the work of extended OCIs. Its the oils and the engines today. Do you own testing. remembers Bob's test when he ran the engine with no filter at all!
