Amsoil Ea oil filter 25,000 miles
NJ
After reading up on the new Ea oil filters, I ordered one for $20 (Amsoil PC cost). I really like the idea of taking this filter out to 20k + miles without changing. Is anyone here in the process of doing so?
My commute to work is increasing and I'd like to change the oil every 10k or so (Redline 5w-20) and skip the filter change until 20k miles. This would be ideal, and would be much less messy! The oil filter on my car creates such a mess when changing it. I HATE changing the oil filters.
quote:
Originally posted by TRDUSA2002:
If you change the oil change out the filter, why people dont change filters ill never understand.
Because there's enough empirical evidence that they aren't even taxed at over 10k of usage. I've seen it with my own eyes. I had to get someone to send me a 10k old filter to ever see one react with any amount of loading. Even with 10k on it ..there were hardly any indications that it wasn't all but 100% functional when the oil was warm. Even in subfreezing weather with 20w-50 oil is never reached the bypass threshold.
That's why I would do it.
I wonder how well the cheapo filters hold up when they have to deal with a lot of short trips in cold weather where you get a significant amount of water built up.
IF the EaO or other types of filtration currently under test( Larry is testing metal wire full flows and Auto-Rx), are as good as we theorize, indeed the paradigm of changing the filter every time we change out the lube may be old hat.
One of the potential issues with running a loaded filter is that as the oil flows past the contained debris it is being contaminated at some level and depleting the oil. Fe contaminants are particularily difficult and will put oxidation rates into hyperdrive. Depleting the add pack prematurely.
I just reinstalled a 4000 mile used K&N oil filter( no EaO made for this 2.4 I4) after carefully draining it as best I could on a oil change for a newer test bed engine. I'll share my oil analysis data as more is collected on the newer Mitsubishi Mivec using 5w20 here in 100 + F temps.
LC could be used as a correction fluid for reducing oxidation and Auto-RX may be able to be used to actually cleanse the filters themselves. If we could cut back on filter changes with a tougher media while keeping wear low, flow at spec, and filtering optimumly then more power to you. Saving money AND saving your machinery is what I am interested in for my customers.
Another thought is that the EaO media was originally designed for soot reduction in diesel engines, our theory that CJ4 thin vis formulas may actually be good for gas engines would be a neat twist using the Eao type media together for your passenger car.
Regardless, oil analysis can verify your choices suitability regardless of variables your engine may encounter.
427 my problem with cheapo FF's is that they are in bypass more than we realize so you do not get the filtering the fluid needs on a continual basis. Water makes it even worse.
TRDUSA2002 , some car's OEM manuals advocate filter changes every second oil change (I know my old car does) so the idea isn't as silly as you think.
No doubt, Leo. If Honda specs their thimbles for 20k, and we all know they're usually Frams when aftermarket.....
Why they do that I'll never know. I've gone the route of doing things well before Honda's recommendations lately. Valve adjustments, timing belt, coolant....you know, the stuff that when it breaks you're screwed!
quote:
Yes Terry-sama. I worded it poorly, but my intent was to alert people that extended drains on cheapo filters may not be wise. I look forward to any continued testing on these quality Ea filters.
