Originally Posted By: Miller88
Dealer markup maybe? I have heard of $400 CVT fluid changes at the dealer.
$400 for a fluid change, and they still won't go 100K miles without failing.
Says who?
My dealer charges $189 for a drain and refill. $400 is probably about right for a full flush, since the fluid costs $15-$20/qt and you need 15 quarts. The service is generally unnecessary though, since you need to check the CVT fluid deterioration value using the factory scan tool in order to determine the need for a fluid change...it is not uncommon for the fluid to be good for well over 100k.
The failure stories are way overblown. Sure, they may have been some issues with the early Murano transmissions, but some of those CVT failures were attributed to leaking CVT fluid due to a bad seal between the transmission and the transfer case, causing fluid loss.
Nissan has stood behind the transmissions very well with the 10/120k warranty, and based on the sales and overall experiences reported with the mass-produced 07-12 Altima, the CVT has been very successful.
Says who?
