Quote:
If you are running 40-50,000 miles a year, then a bypass filter would probably make sense. If you are running industrial or commercial equipment 30-40 hours per week, then a bypass setup would probably make sense. If you are running a commercial fleet, and willing to take oil samples, then bypass setups would make sense. If you are running one or more diesels, bypass filters make a lot of sense.
If you are running 20-25,000 miles a year, personal vehicle, be it a Dodge or Honda, and using AMSOIL with AMSOIL air and oil filters, it is probably not a good economical choice to put on a bypass setup (unless you are a dealer and want to show it off as a sales tool). You can almost change oil and filter for the cost of oil analysis and filter plus makeup oil cost. Not to say that taking an oil sample from time to time isn't a good idea anyhow.
