Oil Brand Amsoilquote:
Originally posted by rgiles:
I noticed there aren't any lab tests done on Amsoil ATF. Has anyone done this or willing to do this. I think it would be interesting to see the composition since they claim to be a universal ATF. Any Amsoil reps care to volunteer to do a sample for us?
TYPICAL TECHNICAL PROPERTIESquote:
Can anyone comment on the additives of this ATF and what is the TAN mean and what is a good value there? How does this compare to any other ATF's? I know the flashpoint wasn't tested, but what is expected for this ATF?
I'm particularly interested in comparing this to another that meet's Mercon V ATF specs.
Thanks.
I would like to compare it to Motorcraft Mercon V fluid since that is probably the original standard and that's what my owners manual requires.quote:
Originally posted by mdv:
In comparison to Mobil 1 ATF, Amsoil has a little less boron and a little more phosphorus. More details on M1 ATF is on the Mobil1 website. What were you going to compare it to?
1) I'm sure the test in performed under a hood with good air flow and not to many guys smoking cigars standing around!quote:
Why would Amsoil test at 250 degrees C when the flash point is 222?
I don't have any to send in but was contemplating getting some Motorcraft Mercon V to compare with the Amsoil. I switched to Amsoil in the Explorer, but I still would like to see what the chemical differences are that might tell a story.quote:
Originally posted by MolaKule:
Do you have a Mercon V to send in for virgin analysis?
What aspects are you going to compare?
Sounds like your mind works a lot like mind - got to get to the root of the chemistry. With ATF chemical analysis of the virgin stuff doesn't tell you THAT much. Comparing the published specs tells you SOME more but still - it'll leave you hanging - because you want to know how it performed for one very specific platform. And you'll typically get: it passed/exceeded the specs, performed by a relatively independent lab....So put this all together and come to a decision.quote:
Do you have any suggestions on what to compare between the two? I think I would like to see the flashpoint, and viscosity ratings to name two. I'm also curious as to what additive differences they might have.
I will send a used sample of the Amsoil at some point but need to get more miles on it.
quote:
Originally posted by Pablo:
Does your rig shift OK? Yes please do submit a sample after xx,xxx miles.
And even though the Amsoil ATF passes the Mercon V tests, I like the Lubegard M-V.It shifts fine, I didn't really notice any difference there. I'm not so certain it has passed the Mercon V tests, but rather is Recommended for use in Mercon V applications. I like the Amsoil over the factory fill because I believe I'm getting a better fluid, but would like more evidence to back that up. Testing Motorcraft Mercon V would provide some of that info, particularly the flashpoint.
After looking over the Mercon V test requirements on this web site, I can see that it would take a small fortune to conduct all of those tests to prove it was a Mercon V fluid. So I don't think they have really run the tests, and if I'm wrong, please post information to the contrary. Even Mobil 1 doesn't claim Mercon V in their ATF but I've heard of others running it successfully.
Absolutely Amsoil has tested and had an outside lab test it to the Mercon V. They would NOT make that claim without testing!!! You are correct - It ain't cheap. The reason for 250°C vs. 150°C, for example, is: 250°C is more rigorous and also more standard - the specs they publish are not just for Mercon V - they are for the ATF itself.quote:
I'm not so certain it has passed the Mercon V tests, but rather is Recommended for use in Mercon V applications....After looking over the Mercon V test requirements on this web site, I can see that it would take a small fortune to conduct all of those tests to prove it was a Mercon V fluid....So I don't think they have really run the tests, and if I'm wrong, please post information to the contrary.....
Yes Amsoil does recommend the 5W-30 for cars that ask for 5W-30 SL. You are not precisely wrong - but "ratings" are different than submiting the oil to API (for example), paying the money and then being bound to API after their approval. Amsoil just doesn't want all the mid and upper notch oils formulations, known to and pretty much controlled by waiting in line for API.quote:
Does Amsoil recommend their 5w30 oil in all vehicles that require an SL rating even though it hasn't been SL approved? I'm not saying it can't pass the tests, I just want to know IF it has. See what I mean? From my understanding, only the Amsoil 7500 oils have SL ratings am I wrong?
