I have a 2003 Honda Odyssey with Amsoil ATF. It should be as close to 100% as you can get with a flush through the cooler line. It was nice and pink for about 2,000 miles...now it is a grey color...also red....but has a grey tint to it. About 7,000 miles on the Amsoil. The van has 76,000 and had the ATF changed at regular 30k intervals with Z1 until I switched to Amsoil. The Honda ATF always looked about the same as the Amsoil does now. Shift quality seems to be okay. I am not sure if the fluid is bad, because of the color or the trainy has a problem. It seems to shift okay, but, I did just buy some more Amsoil ATF. Probably will switch it out as soon as I get a warmer day to do it.
