Amsoil ASL 5w-30 -- Two different formulations?
Kentucky
I recently ordered a gallon of ASL 5w30, listed on Amsoils website. The following applications were listed:
* API SM/CF, SL, SJ ...
* ILSAC GF-4- 3 ...
* ACEA A5/B5-04
* JASO VTW
* GM 4718M, 6094M
* Ford WSS M2C929-A
* Daimler Chrysler MS-6395N
* VW 503.00
I noticed the HTHS viscosity was 3.2 as such it does not meet VW 502 specs.
The bottle I received seems to be a different (perhaps older) formulation entirely. In the applications it does not mention API SM/GF-4 approval, and it does include the VW 502 spec suggesting HTHS of >3.5. On the back of the bottle shows product code ASL-1G. What gives?
I chose this oil due to the product specs listed on Amsoils website for this oil. I wanted something with the emphasis on a thin 30 weight, however the product I received suggests that this is not that case. I'm thinking that this variant is a thick 30 weight since it meets the VW 502 spec of HTHS >3.5.
Does anyone have the published specs for this formulation, or know whether it is different from the one on Amsoil's website? Thanks in advance.
I've heard that Amsoil uses the remaining (old) bottles and packaging even though a formulation has changed. I don't know if that's what happened with you, but it may be a possibility.
I'm don't know what Amsoil does, but, if oil X is not API Certified what is the company required to do?
You ordered ASL1G. This simply means ASL in a 1 Gallon container.
You can be assured it's the latest SM formula, which is the updated web site specification. This formula has been out for some time (almost a year by now).
Good to hear.. Looks like quality stuff.
FWIW, the UPS guy left the package on the porch to sit there all day... I doubt if it reached 30 degrees today. And the oil was still quite fluid and "sloshed" around nicely. Hardly a test by any means, but worth noting.
