Amsoil ASL 5W-30, 2043 miles, 05 Toyota Tacoma V6
USA
vehicle----------05 Toyota Tacoma, 1GR-FE, 4L, 6cyl
OIL-------------5 qt, 13 oz Amsoil ASL 5w-30
oil additive------3 oz AUTO-RX at oil/filter change
oil filter----------Amsoil EAO57
air filter---------Toyota, new at apprx 18,726 miles
miles on oil/oil filter------2,043 (apprx 6 months--May -November)
miles on vehicle--22,856
UOA by Oil Analyzers:
Truck used 1-2 times per week, mostly to work 10-15 miles one way. Some longer trips. Apprx 65% highway. Only a little light towing this OCI. A couple of previous OCI's had a little heavy towing. Previous 2 OCI had some LC20 added. All of these OCI's were with additives added to Amsoil ASL. FP60 used regularly. Use top tier gas-Shell.
Currently running Castrol GTX 5W-30 with 3 oz Auto-RX, & Amsoil EAO57 oil filter. Warranty requires 6 month OCI, so may stick with mostly Castrol GTX w/Auto-RX maintenance dose, til warranty expires. Drained oil saved for later re-use.
Could Auto-RX have freed up some additives?
During this run, once noticed cloud of light blue smoke from exhaust upon startup. To me, that indicated Auto-RX cleaning (around valve stem seals?) allowing oil to temporarily pass through cleaned area. Did not notice mpg increase with Auto-RX in the 100% synthetic oil. However, I do seem to get better mpg when Auto-RX is added to regular motor oil.
To be honest, the 6 month old oil you drained out looks better than a lot of virgin oils. Your engine is boringly clean.
Some folks here have a silly notion that synthetic oils have more wear at low miles (not sure how they came to that conclusion).
Anyway, love to see Castrol as well.
Several of the additives increased, which leads me to think maybe Auto-RX liberated some from the engine metal surfaces.
Virgin Amsoil ASL additive levels are not that high are they?
Look at how low the Zink is for an AMsoil formula so I would say that the Calcium is probably right! THey probably increased it to make up for less ZDDP! Nice does of Boron in their!!!! All looks well.... I doubt you will have any problems with GTX+ARX! should keep it clean especialy witht he low miles driven dureing the 6 months oil change interval!
I'd really like to compare wear rates with Amsoil (ASL, ATM, ACD, ACD/HDD mix) without LC20 or Auto-RX. I assume wear is primarily from the cold startups. I'm wondering if a thicker cold temperature viscosity synthetic oil (Amsoil ACD, ATM or ACD/HDD mix) would provide less startup wear (more separation of the moving engine parts til engine warm). Pablo's recent UOA with ACD would support this theory, would it not?
