Here's some interesting data, from an old thread, on the ratio of kinematic viscosity to HTHS viscosity that is being discussed above. jpr compiled and posted the data...though I've unquoted it so it can be read better.
https://bobistheoilguy.com/forums/posts/1119808/
Originally Posted By: JAG
Originally Posted By: jpr
Independent tests results would be quite interesting, but in the meantime I don't know of any reason not to take Redline's HTHS statements at face value.
Did what I say make no sense? Calculate the ratio of KV@100C to HTHS for Redline. Do same for other straight weight oils and non-straight weight oils. Do it for other high ester content motor oils like Silkolene and Motul 300V. See how the data compares. I'd do it and post it but am too busy today. I did calculate the ratio for pure 8 cst PAO from XOM and it was 3.1. That's like a straight weight oil without any additives so the ratio is on the low end. Having VIIs makes the ratio increase because they increase kinematic viscosity more so, percent wise, than HTHS. Oils like Mobil 1 0W-40 have ratios on the high end due to high VII content.
As a note, when oils are permanently sheared, the percent change in HTHS is about 1/2 the % change in kinematic viscosity at 100C. This is from a study done in the 1980's.
Actually, I just kind of glossed over it at first - but here's some results of Kv100/HTHS based on what I've got handy at the moment. It doesn't include any straight weight or pure race oils, but I see you point about Redline sticking out:
** 10W30 **
Redline Synthetic 10w30 2.82
Mobil Mobil 1 10w30 3.18
Mobil Mobil 1 High Mileage 10w30 3.22
Shell Quaker State Peak Performance 10w30 3.28
Shell Pennzoil Multigrade 10w30 3.35
Mobil Mobil 1 Extended Performance 10w30 3.45
** 10w40 **
Redline Synthetic 10W-40 3.11
Fuchs Titan GT1 10W-40 3.38
Mobil Mobil 1 High Mileage 10W-40 3.62
Shell Pennzoil Multigrade 10W-40 3.68
** 5w30 **
Redline Synthetic 5w30 2.79
Fuchs Titan GT1 5w30 3.18
Fuchs Titan GT1 Longlife III 5w30 3.24
meguin megol Motorenol Quality 5w30 3.29
Fuchs Titan Supersyn (SL) 5w30 3.31
Castrol Syntec 5w30 3.32
Shell Pennzoil Platinum 5w30 3.32
Shell Pennzoil Platinum European Formulation Ultra 5w30 3.34
Amsoil ASL 100% Synthetic 5w30 3.34
Shell Helix Plus S 5w30 3.37
Shell Quaker State Peak Performance 5w30 3.39
Fuchs Titan Supersyn Longlife 5w30 3.4
Castrol SLX Professional LLIII Powerflow 5w30 3.4
Fuchs Titan Supersyn F 5w30 3.41
Shell Q High RPM 5w30 3.42
Shell Q European Formulation Ultra Diesel 5w30 3.43
Shell Pennzoil Platinum European Formulation Ultra Diesel 5w30 3.43
ConocoPhilips Phillips66 TropArtic Synthetic Blend 5w30 3.48
ConocoPhilips 76 Super Synthetic Blend 5w30 3.48
ConocoPhilips Conoco Syncon All Season Synthetic Blend 5w30 3.48
Shell Helix Ultra 5w30 3.49
Shell Pennzoil Multigrade 5w30 3.5
ConocoPhilips Phillips66 TropArtic Full Synthetic 5w30 3.5
ConocoPhilips 76 High Performance Full Synthetic 5w30 3.5
ConocoPhilips Conoco Syncon High Performance Synthetic 5w30 3.5
Shell Q Advanced 5w30 3.51
Shell Q Horsepower 5w30 3.51
Mobil Mobil 1 Extended Performance 5w30 3.55
ConocoPhilips 76 Super High Mileage Synthetic Blend 5w30 3.6
ConocoPhilips Kendall GT-1 High Mileage Synthetic Blend 5w30 3.6
Royal Purple Royal Purple 5w30 3.66
Mobil Mobil 1 Truck and SUV 5w30 3.66
Mobil Mobil 1 5w30 3.66
ConocoPhilips Kendall GT-1 High Performance Synthetic Blend 5w30 4.08
** 5w40 **
Redline Synthetic 5W-40 3.28
Shell Q Horsepower 5W-40 3.56
Fuchs Titan Supersyn Plus (SL PD) 5W-40 3.59
ChevronTexaco Havoline Synthetic (2) 5W-40 3.63
Mobil Mobil 1 5W-40 3.64
meguin megol Super Leichtlauf 5W-40 3.7
Amsoil AFL European Car Formula 5W-40 3.7
ChevronTexaco Havoline Synthetic 5W-40 3.71
Shell Pennzoil Platinum European Formulation 5W-40 3.72
Shell Q European Formulation 5W-40 3.72
ConocoPhilips 76 Pure Synthetic 5W-40 3.76
ConocoPhilips Kendall GT-1 Full Synthetic 5W-40 3.76
Fuchs Titan Supersyn (SL) 5W-40 3.81
ChevronTexaco Havoline Ultra 5W-40 4
Shell Helix Plus S 5W-40 4
** Others **
AMSOIL Signature Series 0w30 3.22
ChevronTexaco Havoline Synthetic 0w30 3.24
Fuchs Titan Supersyn (SL) 0w30 3.4
Shell Helix Ultra 0W-40 3.7
Mobil Mobil 1 0W-40 3.78
