Make/Model: Isuzu 6.6 Duramax LLY
Vehicle: 2004 Chevy 2500HD
Blackstone Comments:
The lead increase caught our eye last time, which is why we're so pleased to see it drop to 2 ppm here. This level is what we're used to seeing from your Duramax and it perfectly matches universal averages. The increase last time wasn't
dramatic by any means, but we'll take lower wear any time. This was a shorter run too, so that may have helped some, but iron is the metal that tracks most directly with miles on the oil rather than lead. No excess fuel or coolant showed
up in this 15W/40 oil. Keep this oil in use and just check back in 5,000 miles or so.
22K sample on 6.13 was done through Oil Analyzers Inc, everything else is through Blackstone.
Code:
OIL Amsoil AME AME 15w40 AME 15w40 AME 15w40 AME 15w40 AME 15w40 AME 15w40 MILES IN USE 13,556 19,740 12,406 20,617 24,757 21,779 19,779 MILES ON UNIT 201,895 188,339 181,364 168,598 147,981 145,003 123,224 SAMPLE TAKEN 1/2/17 1/2/16 8/9/15 8/9/14 8/9/13 6/13/13 6/13/12 MAKE UP OIL .75 1.25 .75 2 0 2.5 2.5 ALUMINUM 2 3 2 2 3 2 2 CHROMIUM 0 1 0 0 1 0 1 IRON 15 24 15 16 17 14 16 COPPER 3 7 4 4 6 3 4 LEAD 2 5 3 2 3 2 2 TIN 1 0 3 0 0 0 1 MOLYBDENUM 0 1 1 1 2 0 6 NICKEL 0 1 0 1 1 0 1 MANGANESE 0 0 0 0 0 0 0 SILVER 0 0 0 0 0 0 0 TITANIUM 0 0 0 0 0 0 0 POTASSIUM 2 4 3 7 0 4 4 BORON 1 7 2 7 5 2 10 SILICON 6 8 6 7 8 9 8 SODIUM 6 8 5 5 6 5 6 CALCIUM 3416 4075 3744 3729 4140 3888 3604 MAGNESIUM 12 13 12 19 33 31 197 PHOSPHORUS 1113 1193 1137 1145 1401 1252 1262 ZINC 1240 1535 1338 1384 1474 1500 1323 BARIUM 0 0 0 1 0 0 0 CADMIUM 0 VANADIUM 0 ANTIMONY 0 LITHIUM 0 SUS @ 210F 74.5 78.6 79.9 72.6 73.2 74.6 Visc @ 100C 14.12 15.17 15.5 13.63 13.8 14.6 14.14 Flashpoint 460 430 445 450 430 430 Fuel % <0.5 <0.5 <0.5 <0.5 <0.5 <1% <0.5 Antifreeze % 0.0 0.0 0.0 0.0 0.0 0.0 Water % 0.0 0.0 0.0 0.0 0.0 <.1% 0.0 Insolubles % 0.2 0.3 0.3 0.3 0.3 0.3 TBN 7.3 7.6 6.9 4.5 7.0 5.8 Soot <.1% Oxidation 53 Nitration 10
