Our move 1yr ago drastically changed the driving routine for my LLY. Went from ~60 miles per day commute down to less than 5. With all of the short trips I wanted to get a sample submitted at 1yr to see the differences. Oil was not changed during this sample.
Make/Model: Isuzu 6.6 Duramax LLY
Vehicle: 2004 Chevy 2500HD
Blackstone Comments:
Leaving the oil in place for a year or longer isn't a problem in modern automotive engines. The oil doesn't go bad and it only accumulates metal with use, so feel free to go by miles or hours instead of the calendar. You've had this oil in place for 12,406 miles so far, and your metals are basically the same as last time after 20K+ miles. That's great! If you do take this oil out to 20K miles, iron may go up a little, and that's fine. the viscosity was thick for a 15W/40, but only barely so. It's not a major concern. The TBN was nice and strong at 7.6, so add 5K miles.
22K sample on 6.13 was done through Oil Analyzers Inc, everything else is through Blackstone.
Code:
OIL AME 15w40 AME 15w40 AME 15w40 AME 15w40 AME 15w40 AME 15w40 AME 15w40 MILES IN USE 12,406 20,617 24,757 21,779 19,779 12,006 9,006 MILES ON UNIT 181,364 168,598 147,981 145,003 123,224 115,451 112,451 SAMPLE TAKEN 8/9/15 8/9/14 8/9/13 6/13/13 6/13/12 3/1/12 1/2/12 MAKE UP OIL .75 2 0 2.5 2.5 0 0 ALUMINUM 2 2 3 2 2 2 2 CHROMIUM 0 0 1 0 1 0 0 IRON 15 16 17 14 16 11 9 COPPER 4 4 6 3 4 2 2 LEAD 3 2 3 2 2 1 2 TIN 3 0 0 0 1 0 2 MOLYBDENUM 1 1 2 0 6 7 8 NICKEL 0 1 1 0 1 0 1 MANGANESE 0 0 0 0 0 0 0 SILVER 0 0 0 0 0 0 0 TITANIUM 0 0 0 0 0 0 0 POTASSIUM 3 7 0 4 4 0 0 BORON 2 7 5 2 10 9 10 SILICON 6 7 8 9 8 7 7 SODIUM 5 5 6 5 6 5 5 CALCIUM 3744 3729 4140 3888 3604 3153 3334 MAGNESIUM 12 19 33 31 197 213 234 PHOSPHORUS 1137 1145 1401 1252 1262 1132 1241 ZINC 1338 1384 1474 1500 1323 1226 1369 BARIUM 0 1 0 0 0 0 0 CADMIUM 0 VANADIUM 0 ANTIMONY 0 LITHIUM 0 SUS @ 210F 79.9 72.6 73.2 74.6 73.0 71.3 Visc @ 100C 15.5 13.63 13.8 14.6 14.14 13.73 13.29 Flashpoint 445 450 430 430 425 435 Fuel % <0.5 <0.5 <0.5 <1% <0.5 <0.5 <0.5 Antifreeze % 0.0 0.0 0.0 0.0 0.0 0.0 Water % 0.0 0.0 0.0 <.1% 0.0 0.0 0.0 Insolubles % 0.3 0.3 0.3 0.3 0.2 0.2 TBN 7.6 6.9 4.5 7.0 5.8 8.7 Soot <.1% Oxidation 53 Nitration 10
