Hello. This is my first post, but I have been lurking since about 2004. I just wanted to share my numbers and get some feedback.
Vehicle is a Mercedes Benz 300TE (wagon) with the M103 3.0L straight six (gasoline). Motor was replaced with a factory replacement in 2007. The miles on car when the motor was changed are unknown. I tried the ACD 10w-30/SAE30 because of the good things said around here about it and because these motors are known to shear oils quickly.
Analysis by OAI. Numbers in both Miles and Kilometers.
Code:
Oil: Chevron Amsoil Amsoil
Supreme ACD ACD
10w-40 10w-30/SAE30 10w-30/SAE30
Miles in use: 3182 7120 10081
KM's in use: 5121 11459 16224
Miles on car: 157407 167982 170943
KM's on car: 253322 270340 275106
Sample Date: 17oct10 21jul11 03sep11
Lube changed: yes no no
Filter Change: Yes Yes Yes
Iron 4 11 12
Aluminum 1 10 4
Copper 4 7 7
Lead 3 6 4
Silicone 9 7 10
Sodium 24 9 8
Potassium 0 2 2
Molybdenum 287 5 3
Boron 55 7 9
Magnesium 17 33 21
Calcium 2192 4715 3595
Phosphorous 963 1330 1117
Zinc 1122 1543 1274
Visc @ 100 deg C 11.7 10.6 10.5
Base # 3.60 4.27 5.40
Oxidation 9 41 39
Nitration 17 22 20
Lube added (qts) 0 3 3
First sample comments: 10w-40 showed shearing. (Ran ACD after this for 3455 mi (5560km) to flush out the previous oils.)
Second sample comments: "Aluminum is at a MINOR LEVEL. Oil is sutable for continued use."
Third sample comments: (Continued fill from second sample.) "Flagged additive levels are higher than expected for the lubricant that is identified. (This does not imply that the lubricant does not meet proper API, SAW, or ISO classifications.)"
Code:
Supreme ACD ACD
Iron 4 11 12
Aluminum 1 10 4
Copper 4 7 7
Lead 3 6 4
Silicone 9 7 10
Sodium 24 9 8
Potassium 0 2 2
Molybdenum 287 5 3
Boron 55 7 9
Magnesium 17 33 21
Zinc 1122 1543 1274
Oxidation 9 41 39
Nitration 17 22 20
