I just received an analysis from Dyson Analysis (Terry).
Vehicle: VW Passat 1.8 turbo
miles on car: 21,000
miles on oil when analyzed: 5,200
oil: Amsoil 5W-30 (the 25,000 mile drain version)
Driving Conditions: It's been very hot and humid with the AC on constantly. I ran it a little harder than normal, but the car does get a lot of highway miles averaging 70-90 mph. Also, with summer my wife does hit some traffic on the way home, so the car does idle for extended periods occasionally. The car is not modified, but I do use the ITG performance air filter (oiled foam similar to amsoil’s) I also use the OEM oil filter made by Mann
Results ppm or % / comments:
copper 5 low,good
Iron 10 low,good
Chrome 0 low, good
lead 4 low,good
aluminum 3 low,good
silicon 12 average,still some bonding agents
leaching, being new.
moly 0 low, not used as additive in this oil.
sodium 1 low, good
magnesium 381 additive,normal
tin 0 low, good
zinc 1090 add, normal
potassium 0 coolant add, there ain't any,good
phosphorus 848 add,normal
calcium 2100 add, normal
water neg neg,trace,pos; neg is good
fuel neg as above
glycol neg as above
soot 0 only applicable to diesels,but
would show solids in a gas engine.
oxidation 55 scale 0 to 199 average
divide by 2 to roughly compare to other labs tests
nitration 143 elevated, we need to see trend
for this engine and oil combo if you keep using it,notes on scale above
apply.
sulfur 0 not real important to gas engine. use for trend comparison
TBN 7 starts at 12 so your engine is
depleting this, like nitration needs to be monitored.
Vis 12.6 thickened to 40w barely,limit
is 12.5 for 30 w. Amsoil is not holding up, I can't see extended drains
with this oil.
copper 5 low,good
Iron 10 low,good
Chrome 0 low, good
lead 4 low,good
aluminum 3 low,good
sodium 1 low, good
tin 0 low, good
fuel neg as above
glycol neg as above
apply.
with this oil.
