I took our Suburban to a shop this morning because there was a bunch of grease packed around one of the upper ball joints, and I thought it had come out of the boot. I haven't noticed any sounds or odd handling characteristics from it, but this is a tow vehicle so I want to keep on top of it.
The tech just called me and said the upper ball joints are fine, no cracks in the boot, and the grease looks like somebody just overzealously applied some lube up there. He did say that both lower ball joints (load bearing ones) have about 200 thousandths of play in them and that if we wanted an alignment they should be replaced. He quoted about $600 for both sides including an alignment.
I asked how critical it was and he explained that if the alignment is fine and the truck doesn't have any bad handling characteristics (which it doesn't aside from being a truck in the first place
) then it's not really a safety risk.
In summary: ball joints have lube, no cracks in the boots, but have some play just from wear over the miles.
Am I making a mistake declining the repair for now? The truck has other problems too and if I'm going to spend $600 on it I want to make sure my priorities are correct as to where the money goes.
