Originally Posted By: Loobed
Get a tire plug kit and do it yourself. I think they are under $10 at walmart. Get the ones with the "T" handle. Usually the glue will only work 1 time, then it dries up. The plugs should look like rubber coated heavy string. The caramel colored ones are better than the black ones. I have had 7 plugs in a motorcycle tire, which are not suppose to be plugged, and the tire lasted 15,000 miles. They guy that changed the tire thought it was odd.
This is how you do it.
1) Fill tire with air
2) open glue and put some on the shaft of the round reamer/file
3) remove nail or screw
4) put the reamer in the hole and move it out like you are making love to it.
5) leave it in the tire for the next part.
6) put a string plug on the tool and put some rubber glue on the tip and about 1/2 way up each side of the string plug
7) pull out the reamer and jam the plug in fairly quickly, but not hard or you will go to deep. Don't keep your face in line with the hole or you will get a face full of glue. The plug should have about 1/4" of each side of the plug visible.
7) twist the tool 1/4 turn than pull it out.
8) squirt some soap water over the repair and see if it is leaking (bubbles), if it is, use a pliers and pull out the plug and start over.
9) fill the tire to normal air pressure
10) squirt soap water on plug and see if it still holds air.
11) use a pair of diagonal cutters and cut the excess string that is sticking out from the tire
I laughed like a middle schooler at steps 4 - 7.
