Yes, definately a positive, as to the straight 40 at low temps, it will be a balancing of trade-offs to resort to that I think, is the engine so tired that all the clearances have opened up that only a thicker oil will relieve so that you can get more life out of it, or is it still not so bad that the right multi-grade will be sufficient to give optimal lubrication with minimal burning (smoke , consumption) that is what it sounds like you are trying to determine at this point.
I wish Doug Hillary was still here to give recomendations as well as he is most familiar with your climate and off the shelf products with much more experience at this.
He may have answered similar questions in the past so you might try searching on that user here.
