I have a similar post about my battery and alternator on here, but am making this post to see what you guys all think. This is sort of a different question.
To make a long story a little longer-
I had a 600 CCA Auto Craft Silver battery in my truck, 2 days ago it went bad and I replaced it with a Duralast Gold which is 750 CCA. Autozone does not stock the red top Duralast battery for my truck. I could have ordered one I guess but I needed a good battery right then. Anyway, the Duralast Gold is a very strong, great quality battery and is doing fine so far.
The original battery for my truck was probably 550 or maybe 600 CCA. The Auto Craft one that failed was not quite 3 years old, date of manufacture was Nov. 2007 and I bought it in January 2008. Now I have a stronger battery but am using the original stock 117 amp alternator. There is an upgraded 136 amp alterator option for my truck, and I just wonder, does the new stronger battery need the 136 amp alternator to keep it charged better? I wonder if a 10 year old 117 amp alternator will have problems keeping this new battery charged. It's the original alternator, and my truck has 135,000 miles on it now. It's a 2001 Dodge Dakota with a 3.9 V6 and a 5-speed manual.
I think it would be smart to just go ahead and replace the old 117 amp alternator with the 136 amp version. Seems to me it would be a good improvement and a smart way to avoid more battery troubles later on. A reman 117 amp alternator is $129.00 at Advance or Autozone. With the LC123 40% off discount code from Advance I can get a reman 136 amp alternator for about $149.00. Either one should fit and bolt right back in place on my engine.
What do you all think?
Thanks for any ideas here.
