Ok I'm about to take this stupid Journey of mine and drive it into a wall and buy something else.
So after spending the money on an AGM Oddesey battery and verifying it was fully charged at 12.8 volts I installed it into the Journey. It held this voltage over night and now a few days later it's down to 11.5 volts.
I know what you are thinking... Bad alternator... But hold one... Let me explain.
I have 14.4 volts all the time while it's running and it never falls below 14 volts with all the accessories running at idle. I have checked for the voltage at the battery and at the back of the alternator.
I have checked for voltage drops on the positive and negative sides of the charging circuits and this checks out.
I even did a full field test and ran the car in this state at 2,000 rpm for 20 minutes and no change.
It's like the alternator is keeping the volts where they need to be but not pushing enough current back into the battery which is weird because then it should struggle with all the accessories on at idle and it doesn't.
Thoughts?
