Alternative oil for the tropics
Believe me I have searched, problem is the online stuff is non existent, its more a case of someone phoning someone who knows somebody.
But yes I will be moving onto the transmission oil next as I am hearing it can be a major issue due to the heat, I have been advised 20k is a regular changing point but to me seems a bit soon but I am open to suggestions.
Ha funny how they get things up and running here I have seen some vehicles hanging on for dear life but still going strong but on the flip side I have seen some beautifully clean antique examples purring along like they just left the showroom.
Also yes I was worried about the fuel here as it is notorious for being of bad quality and high in sulphur. They were working on it as far as I could tell and as they have their own oil apparently they were building a new refinery to bring everything up to spec in 2018-2020 but it was put on hold for some reason and I cannot seem to find any up to date info. So in the mean time I will probably look to change my fuel filter more often.
Just find the local distributor. If you can’t find them, I can at least link you up on another island. There will be a source of what you need somewhere, maybe not the fanciest brand, but something suitable. Go find the fancy fishing boats and as then who supplies their oil.
Yes the price hike is crazy, especially as I have the invoice from my last service in front of me and the filter was a mere £17.07. And yes I have looked at Amazon and the like but delivery can be up to a month, no next day delivery here :D
I think I would leave the filter on it and order a case of them from an online retailer and wait the month it takes to get them. You can probably get a case of MC canister filters for what one costs locally.
Hi all so a little update. I had to go back to the UK for an emergency and now just returned and ready to tackle my oil issue.
I popped into the Ford dealer here with cash in hand ready to buy my oil only to find that they only use Motorcraft ACEA A5/B5, so have decided to carry on searching. I have located a Motul 8100 X-clean EFE with a label of ACEA C2 C3.
I personally have never heard of Motul so was wondering what any of you guys think.
Also while in the UK I picked up the correct filters x3 for the price of 1 here :cool:
ACEA C2 and and API SP 5w30 have the same viscosity, so no issues there. ACEA oils are intended for diesel engines, whereas the API SP oils aren't, so I would stick with an ACEA oil. ACEA C3 would be fine as well.
Some of the Ford standards require a specific test for wet belts, so I'd try to use an oil that meets this standard as well, but if I had to choose between oils that only meet ACEA C2/C3 or only the Ford standard, I'd go with ACEA.
ACEA C2/C3 oils are meant for gasoline and light diesel engines.
https://www.lubrizol.com/company/specifications/acea-passenger/acea-2023/acea-c2-23
I think OP will be better off with C3 oil thou.
Well, ask Google about Motul.
Use it with absolute confidence.
