I recently purchased a 1000cc Honda Talon side by side UTV. The owners manual oil specification says use API service SG or Higher except oils labeled as energy conserving or resource conserving. Then it says SAE 10-30 Jaso T 903 standard MA.
The engine transmission and clutch all run in oil just like a motorcycle does. I wish to not use Honda overpriced oil I would assume there is a oil that does not Have the Honda name on it and is more reasonable priced. What oil is there on the shelf that I can use with good results?
