Only a BITOGer would be this pedantic
He said at the end ,they didn't add it.So did the ATF additive get installed, didn't see it? Sounds like there is no dipstick to add it to.
Did you miss the walker in the back? Lol.At some point you DIY.....
It did not, would require a drain and fill from the side. If it's anything like a ZF 5HP19 he could've started it and then took the fill plug out and put in the additive, otherwise that atf would come flying out of there if it is off lol.So did the ATF additive get installed, didn't see it? Sounds like there is no dipstick to add it to.
We can rule out Shel_B then unless he has a walker.Did you miss the walker in the back? Lol.
Poor guy probably used to.
