Almost got zapped
NJ
In in-laws wanted to me to fix their outdoor light post light. It's always lit and the photocell is not working. Armed with a new photocell and some tools I tackled the project. Turned the light on. Switched a couple breakers and when the light went off, I went to work. Someone messed with the wires inside the outdoor box and bypassed the photocell. I removed the old one, installed the new one and put my hand over the cell's eye while I closed the box and the light went on.. Oops. I got lucky. Guess I never touched the hot wire. Be careful out there. No idea why the light went out with the breaker still on.
That's why I always touch the hot wire to neutral to make sure it's dead.
If you don't want to spend $20, at least just use a multimeter.
120v may put a grin on one's face, but 100kV from an ignition lead will cause you to do the two step!
That isn’t a multi meter. Its a non contact tester.
It’s good for finding things, but you always want to verify it with an actual meter.
I know what a multimeter is and assume the poster I was replying to has one. Presented that option as opposed to touching the hot and neutral together which was probably a joke anyway, no one in their right mind would do such a thing.
I have before. 🤷‍♂️
It’s better than getting shocked. Cover your eyes and boom.
*That tool purchase is just a bad idea. The fluke model even more so.
120v household can kill if you are touching something grounded with your other hand., your ignition voltage will not kill a healthy person, just wake you up..
Wasn't a joke. If the circuit is live, the worst that happens is a pop and a spark and the circuit is dead.
Also handy for when you can't find the breaker for a given circuit.
Been zapped many times, while not pleasant, it’s not a paralyzing shock like many imagine it. Being careful is still recommended though.
Movies seem to have a very large influence on how people perceive things. Like exploding gasoline tanks, or BBQ tanks when shot.
I got shocked by household current when I was about 5 years old and remember it vividly. It was a very weird vibration feeling that I don't want to experience again.
