It's not an "auto" in the traditional sense of transmissions. What you have is an auto shifting manual transmission. Essentially the same transmission you shifted for 40 years, with a mechanism and computer on top of it clutching and shifting for you.Thanks for your reply I guess after 40 years of trucking and finally succumbing to the ease of an auto trans I'm not up on fluids, I thought that if its 75W 90 then it was the same viscosity? but I appreciate the reply
Provided that's what the DT12 of your trucks year calls for and it meets the specs it asks for, yep.so is it natural to assume that gear oil as long as it is 75W 90 would be acceptable to run?
Yes there is, but it is a specification that applies to telematics (communication between electronic devices).Isn't there a TES 663?
