Allis Chalmers WD gear oil
Northern Michigan
I recently tore down my transmission and torque tube in this tractor to replace some leaking seals between the gear oil and hydraulic oil. This tractor has 2 clutches. The main clutch is on the flywheel like most tractors. The other is a wet hand clutch submerged in gear lube, which let's you stop tractor movement without stopping the hydraulics. I already bought a pail of gear lube to put back in but I noticed it said Cam 2 80w90 LS. So it must have limited slip additive already in it. Will that cause issues with the hand clutch?
I would just use regular 80w90. Not sure if the LS would cause issues since it is a wet clutch. Those hand clutches are pretty neat, I love those old WD's. I grew up with Farmalls but always like the Allis-chalmers.
I believe JG HYtran or a fluid like Rotella UTF (10w-30 visc, gl-4 protection) would be suitable for the hydro side which shares fluid with the second hand clutch mechanism. You can run it in the geared transmission side also instead of 80w-90ep, but I would base that on how hot your operating climate is.
