The Firestone Indy 500 set on my i30 have about 38k miles on them.
The tread is maybe a quarter worn. Yes, three quarters left. All the tread grooves, slots, sipes, and whatnot are still there on every tire. I have rotated them at least every 8k mi.
The problem I have with them that is prompting me to replace them is they are dreadfully noisy.
They were quiet for about the first 10k miles, then gradually the noise level rose.
I usually drive this car gently, occasionally opening the throttle wide on straight lines. It isn't a BMW, Honda, Mazda, etc - taking curves fast isn't fun like in a small, nimble car.
Inspecting visually and by hand the only noticable anomaly is mild feathering develops in use on the front. It only develops on the outermost 1 inch of the tread - only on the outside tread block. This is the leading edge (that hits the road first) of the block wearing more than the trailing edge, not a lateral inconsistency.
Does the vehicle have an alignment problem? If so, what is it? Toe? Camber? Other?
Thanks!
Thanks!
