I have a Mazda Protege which didn't have a tire rotation for a long time as far as I know. They still have about 3-4 mm tread. I think the rule is when only 1mm tread is left then replace, so these should still be Ok. Also we hit a few bumps here and there, so I took it for alignment. The service man told me I also need a new set or tires, which I declined. They are not new, but 3-4mm tread should still be fine.
After alignment my wife told me it still drifts to the left, albeit less than before. She went back to ask why and after a test drive he told her that tires are [censored] and causing the drift.
My questions are about rotation and tread. When do tires need to be replaced? 1mm tread? 2mm tread?
When rotating I didn't pay any attention to tread. I just tried to do the usual back/front swap. Should I also try to match the tread depth? Am I supposed to measure tread on all tires and place the worst pair in the back and the best pair in the front regardless of their previous position? In general what are the main factors when choosing the new placement?
Can different tread depth cause car to drift to the left/right even after a perfect alignment?
thanks
thanks
