Airline maintance requests
washington state
After every flight, Qantas pilots fill out a form,called a "gripe sheet," which tells mechanics about problems with the aircraft.The mechanics correct the problems, document their repairs on
the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by Qanta's pilots
and the solutions recorded by maintenance engineers.
By the way, Qantas is the only major airline that
has never had an accident.
(P= The problem logged by the pilot.)
(S= The solution and action taken by mechanics.)
P: Left inside main tire almost needs
replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200
feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny. (I love this one!)
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit. (This one's great, too!)
S: Cat installed.
P: Noise coming from under instrument panel.
Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
You forgot:
P: Oil seepage on #4 prop shaft.
S: Oil seepage normal.
P: #1, #2, and #3 prop shafts missing normal seepage.
Dave
that joke shows up as Air Force, delta, united, etc write ups, now qantas. it's funny how this stuff gets changed then comes back around.
BTW prop oil leakage is normal! especially if the crew doesn't leave the bird with #1 blade on each prop at the 12 o'clock position!
A models were long before me. I only worked on "new" 1963 e model -7 engines and ham standard props. they still had that leak, it would leak out of the small beta shaft (i think that's what it was called) on the #1 blade. another funny thing about props/blades is the crew chiefs or crew think the prop must be at a perfect "X" before starting the engine. we'd go out and bump the prop but not be at an "X" and they'd want it bumped a little more.
sorry for the OT guys, just a little C-130 talk.
