I see a potential solution for mounting remote bypass filters on crampted installations. The air hose quick connect fittings may be an excellent way to connect the hoses to the filter body. I was looking at them the other day at Harbor Freight. Since they are "Air Tight" they should also be oil tight. When the female side is disconnected, it becomes leak free.
Benefits: Ability to remove the housing easily for servicing under the hood. My van isn't known for roominess in the engine bay until the fan shroud is removed.
Liabilities: Oil flow volumn through the connectors.
My van has cooler lines for both the engine oil and transmission. I plan to filter both components.
Comments will be appreciated on this.
