Originally Posted By: sayjac
Since the linked author references his "oil filter study" prior this AF test some points were made on the oil filter board when it was posted there. Upon closer inspection it was noted that the same oil filters, eg. Napa Gold and Wix, Fram Extra Guard and High Mileage(same media), showed very different test results. What's different though is that many/most of the oil filters have published efficiency ratings, not so true with air filters. For the oil filters, I'm going to be more inclined to believe the tested efficiency ratings done under controlled conditions (ISO test), then some random guy's patch/particle test done in his basement. Here the only identical AF's I recognize is the Napa Gold and Wix.
No AF published ISO test eficiency rating to refer to, the most I'd take from this test is that the K&N and True Flow fall outside of the filtering norm 'in his test.' Beyond that, I'd not be concerned with using any of the other air filters. For the record, I generally use a standard Fram AF filter (not tested), and change it ~30k intervals.
Much like the oil filter test a nice effort, but imo too many uncontrolled variables to give the test results too much credence.
Pretty good synopsis, sayjac.
I do see some value in this test, if you grant that they were consistent in their methodology (maybe they were, maybe not) because it gives you some idea how the filters rank. If you compare it to the Spicer test of about 8 years ago (which was done to ISO specs) there are some very general correlation trends to this one but there is really no way to compare this test to any published efficiency rating done to standardized tests. The Spicer test is still the best but it's too bad it's now so old.
