Air Conditioner oil - how much to add?
SD
I am replacing the compressor, accumulator, and hoses (leaving in place the original condenser and evaporator) on a '06 Jeep Liberty. Total system oil capacity is listed at 8 oz. How much would you add in this situation?
If you need to buy oil only buy denso nd8 which is for non electric r134 system unless it already comes with the components if they're available. If not available and you have to buy some cheaper grade components dump it out and put the nd8 if you want it to last as long as possible. It's the best stuff available, double end capped and highly additized. It's hpl in comparison to the unadditized single cap pag oil that is golden state sae 30 in comparison you get off the autoparts shelf. I don't trust that ice32 stuff it doesn't look like an additive pack more like a different oil in an oil.
As for the capacity do an oil balance and measure what comes out of the compressor and accumulator.
Thats a sanden compressor so it has an oil sump. Thats what that bolt on the middle of the compressor body is. You put oil in there. Not in the lines.
Most of the oil should stay in the compressor. If I was doing this job I would measure what came out of the old compressor and add that much back in plus another 1.0-1.5oz depending on its past service history if available.
Always better to slightly over oil vs under oil.
Thanks for the replies. Unfortunately, not much (an ounce at most) oil came out of the compressor, but it looked good (golden and clean).
Reference charts say the condenser and evaporator together should hold roughly 3 oz. That would leave about 5 oz in all the components that I’m replacing. At least that was my thinking, but I’m no AC expert.
@Chris142 Here is the label on the OE compressor. It says Visteon/Halla
Can you get me a better pic of the compressor? That dont look like a sanden.
Well that's odd. I have never seen that style of compressor on that engine or model jeep. Forget what I said. The oil has to go into the system. Since nothing came out all is a guess. I would put 4.5-5oz in there.
HS-18 was the standard compressor on Liberty. Chrysler used and still uses quite a number of Visteon now Hanon compressors
