Air Conditioner High Low Pressure
im no expert on vehicle AC, But google a d youtube AC Schrader valves.
Apparently its common for them to leak, and you can buy new schrader valves for cheap. Need a schrader valve tool to remove them, that too is cheap to buy.
So before you go spend a lot of money on AC repairs, google/youtube schrader valves.
I too have an ac leak and i suspect it might be both the high and low schrader valves.
i need to buy the valves and tools, and if it works, i can try an AC recharge kit next month on my 20 year old suv Nissan 2.5L.
Apparently, mechanics often realize the valves leak, but can be sneaky, charge you for hours of labor , pad the bill, and replace just the schrader valves, with the customer unsuspecting.
just saying.
I do not think they will be able to change the Schrader valves without loosing the charge, and then having to recharge the system.
Some inner tubes have a cap that doubles as a Schrader valve tool. I have one on each of my bikes so I do not have to carry the tool with me.
You can change out the Schrader valves without losing the refrigerant charge or evacuating the system with a special tool like this Lichamp Valve Core Replacement Tool.
If you can't change out the valve core (or the valve core threaded interface is damaged), replacing the plastic dust cap with these Dorman 902-025 brass plugs and Teflon tape will prevent the refrigerant from escaping.
I am home from the trip now. No airflow problems at condenser or cabin.
I suspect the ECM. I have OBD Link reader but does not show anything about AC controls.
I have had occasional throttle problem. Its not the pedal or the throttle body and its controller. I usually unplugged the harness connector and made sure the contacts were clean and moisture free. Sometimes the connector would come loose and all I had to do was make sure it was firmly pushed in all the way.
I suspect the real problem is the ECM itself. On this last trip The throttle was no problem at 80 MPH highway speed, only at low speeds. I was driving at speed with the light indicating the throttle was acting up. I would stop to fuel up and then start the car up w/no low speed throttle problem. I did not fool with the connector as I would be traveling at 80mph for hours. I could go for about 100 miles before the warning light came on again. Next time I fueled up and immediately took off and the indicator light would stay off and the low speed throttle worked well for another 100 miles. This happened over and over. I am retired and rarely drive over 50 miles at a time so the throttle does not act up very often.
That's why I think the ECM is causing the Low side Hi pressure. what diagnostic tool will read ECM to see if it is causing the problem? Would somebody like Autozone be able to get a module reading? Is there some other AC module not part of the ECM that regulates the high and low side pressures?
A normal OBDII tool won't. You need something more advanced like an Autel. I have an X-Tool D8. For my Chrysler vehicles I also have the same tool the dealerships use.
The ECM controls engine functions such as timing, fuel injection etc. AC is normally handled by the PCM and BCM. Of course, it can vary from manufacturer. Some vehicles have a dedicated HVAC control module. Having a FSM (Factory Service Manual (if available) is the first thing I obtain whenever I acquire a different vehicle. The pressure varies depending on fan operation, ambient temps, compressor cycling to name a few. Lots going on there.
If you're having other module related issues then it could be a clue. I'd check ALL the wiring for possible damage, breaks, chafing, abrasion and poor grounds. The modules are well protected usually in beds of silicone or epoxy resin.
Ask around among your friends and friends of friends. LOTS of guys have advanced scan tools these days.
The fan is not working. I checked the relay in the fuse box. It is OK. Ran 12v to the big slot the relay plugs into. Still no fan. Broke my finger so won't work on the car for another month. Will check the rest of the harness to the fan then. Engine runs at normal temperature w/out the fan even in slow traffic.
The compressor makes such a racket that I am afraid it is bad. I have not run AC since I noticed it was not cold enough.
Considering buying gauges, vacuum pump and etc as I think I can buy them for less than it would cost to have somebody good to replace compressor, and a small Oxy/acetylene set so I can do my home AC repairs. Used to do AC work back in the dark ages.
I noticed that 2013 is the cut off date for 134 A for the Fiesta. Noticed that OEM compressor is the same all the way to last year the Fiesta was made.
The compressor noise is likely due to abnormally high pressure and it may be fine once the fan is working.
As you noticed keeping the engine from overheating really doesn't need the fan unless the car sits still for a rather long time.
Fan replaced. Did not think that was the cause as the extreme high low pressure occurred immediately On starting the car and turning on the AC. 30 seconds not enough time for evaporator not getting cooled to be a factor.
The compressor was replaced 8 years ago so I don't think too much refrigerant is a factor.
There is a Y fitting at the bottom of evaporator with a solenoid connected to it. It's on the High side, small dia line. Could that be a problem.
If there is a blockage in the low side, where could it exist? before or after the evaporator?
You’re focused on the wrong thing. Your number one problem is the high side pressure is far too high. Pour some water over the condenser and I bet the air will be cold unless you already ruined the compressor from running it too long with high pressure. If I were a betting man, I would say the stems from failed refrigerant pressure sensor or the wiring for it.
Look at the pictures in my original post. High side is below normal. Low side is way above 100, Guessing 120+. Low side being the larger dia. line to the compressor.
You need to recheck the photos. It appears that the 2nd photo shows 120 psi on both the low and high sides which indicate equalized pressure when the compressor is NOT engaged. The 3rd photo shows 50 psi (low) and 375 psi (high)...both of these readings are excessive suggesting an overcharged condition or inadequate air exchange across the condenser.
Thanks for the heads up. Low appears in normal range and High is way up in the danger zone. Right you are. The only high side sensor on the Fiesta I am aware of is at the condenser. If it records a low high pressure it will not allow the compressor to operate. Begs the question why not a sensor to detect extreme high pressure to switch the compressor off.
I had not needed AC until shortly before driving to Ohio in May from Texas.. I turned AC on one afternoon during Austin rush hour. Noticed it was blowing warm air and heard compressor whining. Was several minutes before I shut it off as I was dealing with a dicey High speed freeway situation.
Only turned on AC momentarily since then to check things.
I sprayed cold water on the condenser as the compressor ran and immediately got cold air blowing out the vents on the dash. The compressor got a lot quieter after that. Not all the inner plastic parts that channel air to the condenser are fitted correctly to direct air to the condenser and radiator as I had hit a hog early Spring at low speed.
I may indeed have ruined the compressor as I did not realize it would run with AC off but defroster on set at high heat.
Besides the condenser situation is there anything else to consider?
I suspect the fan works as I was driving in mid 90F weather with no overheating. Will Hot wire the fan to see if it works as it is cool here.
My cooling fans immediately go to high speed whenever the A/C is tuned on.
With the A/C off, the fans will come on low speed at 216F and then go to high speed at 221F.
