Air compressor oil
Palmer, AK
Is SAE 30wt (non detergent) still what to use in a piston air compressor?
I can get Cetus but only in 5 gallon pails, which would last me probably a lifetime. Compressor holds maybe 1.5-2 quarts.
Short answer yes but maybe have better options currently running HPL in my 7.5hp piston air compressor was purchased in single qts.
any HF near you?
I've seen ND30 cause rings to stick on air compressors.
I'm sure others will disagree, but AW46 works just fine in that application.
HPL and call it a day. No need to buy so so oil in 5 gallon jugs to just have 90% drop out it's add pack because of you bought too much for a given 5 year oil life in the jug, as is a common industry time frame give or take to store oils.
