- Joined
- Apr 13, 2025
- Messages
- 687
There is a product made by AeroCosmetics made for aircraft that I use on ALL my vehicle tires, including my full size spares. It is a moisture displacing, UV blocking, rubber reconditioning solution (or at the very least, helps slow the loss of the petroleum compounds that keep it pliable and prevent cracking from dry rot.)
If you're going to have a spare sitting unused for decades, spray it with this every other year and it will last for all eternity.
(I also use it on everything rubber or plastic on my vehicles.
Just remember to always SHAKE THE SOLUTION WELL before use.
If you want to go really all out (Like I do), remove all the air in your tires and replace with Nitrogen.
Not only because Nitrogen is a larger, less permeable molecule, but MOSTLY because when you fill your tires with AIR you're usually also filling your tires with WATER vapor. Compressed Nitrogen won't do that unless you're getting junk Nitrogen refills.
I've been using the Aero Cosmetic for years and love it. No shine, just a new rubber look. Seems to work as I haven't had any cracks even on Michelin tires since I started using it. Recommended by Boeing and Airbus for rubber care on their aircraft.
303 never rocked my world. Tried way back when and didn't take to it.
