My daughter drives the old Toyota Camry and it has factory power door locks but no keyless entry (and FOB's). I think I'll add a keyless entry system for the convenience and to help it feel a bit more updated.
I can't decide if I should make it unlock all the car doors with a single push of the FOB unlock button, or plan for an installation for the progressive (sometimes called priority or two-stage) unlock. I think most of the OEM systems use the progressive unlock where the first push of the button unlocks the drivers door and the second push will unlock all doors. That would be a bit more complicated because it looks like I would have to cut a wire going to the drivers unlock motor and add a relay, but I think I can figure it out if warranted. Also, to have this feature it looks like I will need to make sure the system I select will offer the ability to do this - many of the lower-end systems that I've looked at don't.
So my question for those with the keyless FOB's, do you generally prefer that all car doors open with a single push of the FOB button or do you really like and use that progressive unlock feature so you can just unlock the drivers door?
In addition, most of the aftermarket systems have an alarm feature but I don't know if that's really going to be useful on a 20+ year old Camry? However since I'll have access to most of the wiring and not many more connections, should I go ahead and hook an alarm up or is that just asking for frustration and false alarms?
